Engine Mechanical problem
2000 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
I have an Electrical problem with our 2000 Oldsmobile Alero because it will not turn over. I went through all of my electrical Wiring to check & see if I had good connections. Then I started off checking other things like my starter & battery and took them into checker auto store & had them tested & they came out fine & up to working order.So I went back home & re-installed them. So I went in & asked some people that worked at Auto Zone. They ended up telling me that it was the Safety Neutral Switch that needed to be replaced so I ordered another & I replaced it & to this day our Alero is still sitting in the same place. I don't know what else to do..???? HELP..!!!
Oct 17, 2010 at 5:01 AM
