2000 Oldsmobile Alero injectors not working
2000 OLDSMOBILE ALERO
TRIBALBAT1818
Electrical problem
2000 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
replaced my ignition now car will not start ignition good checked fuel pump spark plugs coil belt hoses every thing working correctly double checked still good i did not remove battery when replacing ignition i think that this is causing the injectors to not open up and spit fuel out question is how do i fix this problem do i need to turn the key on and off for a set code remove a fuse or battery or something else i know everything else is in working order this is the only thing left to try to fix
please help me
Jul 15, 2009 at 1:44 PM
STEVEW84
  • 673 POSTS
how are you testing everything? What are you using to check for spark, fuel, and injectors not working. Do you have any codes?
Jul 15, 2009 at 1:52 PM
TRIBALBAT1818
loosened up fuel line going to fuel rod started car fuel spit out properly for sparks installed new plugs and hooked a wire up to the car frame and connected to coil to test for sparks i think i need a code to input so the computer will allow the injectors to work does anyone have an idea or trick i can use and try
Jul 15, 2009 at 2:18 PM
STEVEW84
  • 673 POSTS
you need to get a fuel gauge first and see what your fuel pressure is. Then you need to get a noid light to see if you are getting a control to your injectors. You also need to see if you have an immobolizer problem with your key fob.
Jul 15, 2009 at 3:06 PM
