how ecactly do i access the bulb to change the headlight
May 18, 2010 at 1:51 AM
✓Experienced Mechanic
You should be able to from under the hood. If you can't, check for two metal slides on the rad support near the light assembly and pull them up. That should detach the headlight assembly so you can pull it out and replace the bulbs.
