2000 Oldsmobile Alero Fuel System
2000 OLDSMOBILE ALERO
13,000 MILES • 6 CYL • FWD • AUTOMATIC
GARYMF
2 months ago I changed the Origianl fuel pump. Since then I have burned out 4. I have replaced with Delphi pumps, oem. Anything that would cause this? were there wiring changes, etc, etc.
952-224-6363
Thanks Gary
Aug 12, 2010 at 12:51 PM
  • 110,244 POSTS
Are you sure the regulator is good? It could be causing a problem. There are no wiring updates.
Oct 25, 2010 at 2:53 PM
