2000 Oldsmobile Alero flashers clicking
10,000 MILES • 4 CYL • FWD • AUTOMATIC
GBLA115
the flasher clicks when not in use, turn signal and hazards do still work. I isolated the noise to the hazrd flasher switch and replaced it, the new one does the same thing. I also checked the bulbs to ensure they wee good. could wrong duty rating of bulbs be problem?
Sep 21, 2010 at 5:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely culprit is actually the multi function (turn signal) switch, not the hazard switch itself.
Sep 28, 2010 at 2:09 PM
