2000 Oldsmobile Alero Excesive fuel usage
2000 OLDSMOBILE ALERO
247,000 MILES • 4 CYL • FWD • AUTOMATIC
GEORGE D
I cant figure out why my car is going through a full tank of gas for every 250 kms. Can you please help?
Feb 27, 2010 at 4:30 AM
ERNEST CLARK
  • 1,730 POSTS
There could be one of several things causing you to guzzle gas, even a combination of things.
First, make sure your fuel gauge is working properly. Now here's a list of things to check:
Coolant temp sensor (may be causing you computer to stay in "Open-Loop")
Leaking fuel pressure regulator/injectors
Old O2 sensors
MAF/MAP sensors or the computer itself.
And finally, is your transmission shifting out of first??? And if you are getting any check engine lights, have your computer scanned.
Feb 27, 2010 at 10:54 PM
