2002 Oldsmobile Alero fuel pump
JTLEWIS
  • 2002 OLDSMOBILE ALERO
  • 6 CYL
  • 102,000 MILES
My engine just keep turning over when I turn the key. Is this a problem with my fuel pump or soom lesser or greater pain.
Friday, June 18th, 2010 AT 3:37 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, June 18th, 2010 AT 3:51 PM
