2000 Oldsmobile Alero engine won't start
152,000 MILES • 4 CYL • FWD • AUTOMATIC
DJD3WILL
while driving up a small hill car started to lose power then it died and woudn't restart sounds like it is not firing. Have replaced spark plugs and checked pcm and coils. thanks
Oct 15, 2010 at 9:51 AM
JDL
  • 16,098 POSTS
If it cranks good but won't start, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autrostores used to loan out a fuel pressure gage.
Oct 15, 2010 at 11:05 AM
