2000 Oldsmobile Alero AC Clutch
116,000 MILES • 4 CYL • FWD • AUTOMATIC
JVALERO
Can the AC Clutch be replaced on the AC compressor without removing the compressor from the vehicle? What special tools are needed?
I would like to do on the vehicle so the charge is not disburbed. The air conditioning does works fine. The clutch is quiet when it is engaged. However it is intermittant noisy when dis -engaged.
Apr 19, 2008 at 1:19 PM
LEGITIMATE007
  • 5,121 POSTS
you probably can but it wil be extremely tedious. Its probably not worth it.
Apr 26, 2008 at 5:47 AM
