1999 Oldsmobile Alero Windows don't work
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBEJARANO
I recently bought a 99 alero, but none of the windows work except the drivers. The previous owner said something about it being the "clips". That they had been broken. Also, the driver's side window only works sometimes. What could this be?
Jul 21, 2008 at 10:01 AM
DISVIL
[quote:d1a1f50727="dbejarano"]Interior problem
1999 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic 146000 miles
I recently bought a 99 alero, but none of the windows work except the drivers. The previous owner said something about it being the "clips". That they had been broken. Also, the driver's side window only works sometimes. What could this be?[/quote:d1a1f50727]
Jul 28, 2008 at 3:57 AM
DISVIL
[quote:ef16cefee0="dbejarano"]Interior problem
I recently bought a 99 alero, but none of the windows work except the drivers. The previous owner said something about it being the "clips". That they had been broken. Also, the driver's side window only works sometimes. What could this be?[/quote:ef16cefee0]
Most probably,your little electrical motors that drive the windows,need brush replacement.If you are a handy man,you can do it yourself and save a lot of money.Brushes worn out are a very common problem on American made cars.
Jul 28, 2008 at 4:01 AM
