Brakes problem
1999 Oldsmobile Alero 4 cyl Wheel Drive Type unknown Automatic 110,00 miles
i have a 1999 olds alero with the anti-lock brake light and trac off button staying on. i was told it was an abs sensor that was bad. is this true? if so is it an easy fix or does the hub bearing need replaced again. i had the hub bearing repaired last year and was told the sensor is bad on the left which is the hub i replaced. how much does the part cost and is it separate from the hub bearing or built on it?
Feb 26, 2008 at 10:58 AM
