1999 Oldsmobile Alero power windows
70,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS.K
I have three power windows that are not working. The all fell down inside the door on different occasions, and I have them proped up to the closed position with pvc pipe. How much can I expect to pay to have them repaired.
Nov 11, 2009 at 10:03 AM
KNOWYOURAUTO
  • 113 POSTS
The usual banter as always depends on where you live and if you go to a dealer for the service. Typically a window regulator, (not including the motor), will cost a minimum of $150 each and may go as high as $350 each for the regulator and window motor assembly.
Regards,
KnowYourAuto
Nov 14, 2009 at 3:20 PM
