Whle trying to clear a mouse nest from my blower cage, I had to remove the BCM from under the dash to get to the blower moter mount. In the process, the BCM box opened and the circuit fell on the floor. Upon completing the repair and putting everything back together, the car would start but immediately stall. Thinking the BCM was damaged, I replaced it only to find the same problem. I purchased a code reader and the only trouble code is P1632 - Anti theft fuel disabled. I have a two book manual that talks about a re-learning process to re-train the BCM, but it has not worked. I need to know how to fix this or how to bypass the anti theft device in order to get the car to start.
Jul 12, 2009 at 6:24 AM
