1999 Oldsmobile Alero odometer
1999 OLDSMOBILE ALERO
CHRIS.K
Electrical problem
1999 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
The digital readout on the odometer is no longer lit. All other instrument lights functioning properly
Sep 6, 2010 at 4:34 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Sound's like you just need a new bulb for your odometer.The bulb should be under 10.Would that be something you would want to replace yourself or are you going to go somewhere to have it replaced?
Sep 6, 2010 at 5:26 AM
