1999 Oldsmobile Alero missfire on #1 cly
DARRELL EBLING
  • 1999 OLDSMOBILE ALERO
Engine Performance problem
1999 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
have missfire on #1 cly
Wednesday, November 4th, 2009 AT 3:13 PM
Check no. 1 sparkplug, compression and injector
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Wednesday, November 4th, 2009 AT 5:49 PM
