1999 Oldsmobile Alero location of dip stick
WIGGERS
Transmission problem
1999 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic sedan miles
just purchased used 1999 Alero, transmisision leak, however can't find dip stick location.
Dec 24, 2007 at 4:44 AM
MERLIN2021
  • 17,250 POSTS
You may not have one! Some of the GM's have just a red plug, you will need a lift, or a way to raise it enough to get under and check the fluid, book says remove plug, fluid should be leve with the bottom of the hole...
Dec 24, 2007 at 5:15 AM
