1999 Oldsmobile Alero Fuel issues
1999 OLDSMOBILE ALERO
111,670 MILES • 6 CYL • 4WD • AUTOMATIC
CASSBEAUTY2005
My car runs fine accept when the car is standing still. At a stop sign/light the car sounds like its struggling to stay on and once when I pulled from a stop light the speedometer went crazy when I press the gas and the car jerked. But it immediately went back to normal and hasn't done it since. I fear its my fuel pump because I can hear it shut off when I shut my car off. But I was told I needed to get my fuel regulator fixed anyway. I was just wondering what the problem REALLY is...PLEASE HELP!!! p.s and I feel like my fuel efficiency has decreased as well
Mar 11, 2010 at 3:02 AM
  • 110,240 POSTS
The fact the speedo went crazy indicates something different to me. However, you could still be right. What I need you to do is check fuel pump pressure and the regulator. Here is a how to for checking both. Let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Apr 7, 2010 at 6:24 AM
