1999 Oldsmobile Alero fuel injectors
1999 OLDSMOBILE ALERO
12,000 MILES • 6 CYL • FWD • AUTOMATIC
STACEYPETTYJOHN
Had someone replacing head gaskets, spark plugs and wires. But after putting engiene back together there is one fuel injector that keeps spitting out gas as you try starting it. What could cause this and how can we fix it? Is there a clip or seal that I need to get to fix it with? Thank you for any help with this matter.
May 2, 2010 at 6:20 AM
When you crank the engine over the injectors should be spraying fuel in a cone shape pattern not broken up-Check the injector solenoid resistances with an ohmmeter
May 2, 2010 at 8:30 AM
