1999 Oldsmobile Alero fuel filter
1999 OLDSMOBILE ALERO
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEE ANDERSON
how to remove fuel filter?
Dec 22, 2009 at 4:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Relieve the fuel system pressure.
Remove or disconnect the following:
Fuel line from the filter, using a backup wrench
Quick-connect fitting from the fuel filter by compressing the tabs while pulling outward on the line
Fuel filter from the mounting bracket
Install or connect the following:
Fuel filter to the mounting bracket
Fuel line using a backup wrench.
Torque the fitting to 20 ft. lbs. (27 Nm).
Quick-connect fitting to the fuel filter
Negative battery cable
Pressurize the fuel system and verify no leaks.
Dec 22, 2009 at 4:37 AM
