1999 Oldsmobile Alero firing order
1999 OLDSMOBILE ALERO
MCDONALD 18
Engine Mechanical problem
1999 Oldsmobile Alero 6 cyl Front Wheel Drive Automatic
I need the firing order for this car i just put the engine in. it still misses real bad. so you can give me your advise on what it could be
Mar 1, 2010 at 3:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Firing order 1-2-3-4-5-6
make sure plugs are gapped correct at .060 (In thousandths of an inch)
also check for any loose vacuum lines you may have missed
Mar 1, 2010 at 4:42 AM
