1999 Oldsmobile Alero Engine code
77,888 MILES • 6 CYL • FWD • AUTOMATIC
DENIECE
  • 7 POSTS
a code came out PO442.small leak in e-vap where do I start looking can you help me please.Thank you!
Aug 28, 2009 at 11:45 PM
  • 110,248 POSTS
It could be anywhere, and chances are you won't find it. What I recommend it to have the system fogged. They will pump fog into the EVAP system and it will leak out where the problem is.
If you don't do it this way, you may drive yourself crazy.
Sep 11, 2009 at 4:50 PM
