1999 Oldsmobile Alero Car stalling
146,000 MILES • 4 CYL • FWD • AUTOMATIC
STUDDYBOY
My olds alero recently started stalling. I had a major tune performed along with fuel injector service. Now the car is stalling and not idling properly. When driving at speeds over 50 mph there is no problem, when the car slows the tach meter is dropping to about 200 rpms and causing the car to cut off. This has also happened while the car was coasting at about 40 mph, the car starts right back up but is stalling in some very bad places like on the beltway in my area. help.........
Sep 29, 2010 at 10:17 AM
  • 110,246 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Has the idle air control valve been checked? EGR? Fuel pressure?
joe
Oct 25, 2010 at 9:38 AM
