1999 Oldsmobile Alero 1999 Alero starts but cuts off after
1999 OLDSMOBILE ALERO
220,000 MILES • 4 CYL • FWD • AUTOMATIC
DIONNAJAY
MEMBER
1 POST
I have a 1999 Olds Alero. It starts, then quicky shuts off. there is also the smell of gas and white smoke coming out the back. PLEASe help!
Feb 3, 2009 at 9:23 AM
✓Experienced Mechanic
Hi:
If you are getting white smole from the exhaust, it may be a head gasket problem. Has the car been using coolant? If so, you need to do a compression test to see if there is a head gasket problem.
To do it, go to this page for directions. Also, many parts stores will lend or rent the tool.
