1999 Oldsmobile Alero
140,000 MILES • 4 CYL • FWD • AUTOMATIC
JBELL24_99
I had a bad vibration, so I changed pads and rotors took car for a drive and now my brakes are smoking. I figured my calipers were sticking so I replaced the calipers and they are still smoking, and the brakes dont seem to be what they should be. The ABS light and the parking brake light are always on. What do I do next.
Feb 22, 2010 at 1:42 AM
  • 110,248 POSTS
Did you bleed the system? Is the master cylender full? Also, have you checked the rubber brake hose that attaches to the caliper? Many times they go bad inside, allow fluid to actuate the caliper, and then not release it.
Apr 7, 2010 at 6:36 AM
