2000 Oldsmobile Achieva Engine Missfires
700,000 MILES • 4 CYL • 4WD • AUTOMATIC
BUBBLES4LIFE
I was with my Friend deciding if it would be wise to buy a certian car. I was listening to the engine while it was running and it appeared that the engine may have a misfire. my friend and I both decide that if it is only an ignition problem, my friend would buy the car.
Could you help explain in detail some simple testing I can do to find out if the problem causing the miss is more serious ( Bad piston, Bad valve etc.) The only tools that were given to me are a screwdriver, pliers, and a test light.
Jun 18, 2010 at 2:09 AM
  • 75,988 POSTS
Get a compression gauge and do an engine compression check both wet and dry tests to determine the engine condition this is your starting point
Jun 18, 2010 at 2:42 AM
