Heater fan stopped working?
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
KITEMAN
I had the heater on and switched it to high and I lost all speeds. I checked the fuse and it is OK. Are there any other fuses or relays I should check, if so where are they.
Nov 19, 2008 at 7:27 AM
  • 110,246 POSTS
Hi:
You need to start at the motor and work back. Check for power to the motor. If power and the motor doesn't run, replace the motor. If no power, move to the blowermotor resister. If power in but not out, replace resister (most common problem). If no power in, move to the switch and see if there is power both in and out. If power in and not out, replace the switch. If no power in, you will need to follow the power supply back to determine where it's lost.
Let me know if this helps.
Dec 20, 2008 at 3:59 PM
BGWILLS
  • 0 POST
I am replacing the blower motor and need some advice on how to do it?
Dec 7, 2022 at 2:14 AM
  • 110,246 POSTS
Is the vehicle the same year, make, and model as the vehicle? Let me know.
Also, here is a link that explains in general how to replace the blower motor. If I can confirm this is the same type of vehicle, I can get you the specifics.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Let me know if that helps.
Dec 9, 2022 at 1:53 PM
