1998 Oldsmobile Achieva no antifreeze
1998 OLDSMOBILE ACHIEVA
201,000 MILES • 6 CYL • FWD • AUTOMATIC
REBELMOM3
My car got hot this morning and it is only 19 degrees outside could this be from no antifreeze in it. It was not leaking any water at all and if so could it thaw out and be okay then.
Dec 10, 2009 at 2:25 AM
  • 31,937 POSTS
HI there,
In cold conditions you must run anti freeze, if not you run there risk of doing serious damage to the engine, you will have to ensure it is completely thawed and then check for over heating issues, if OK, get the anti freeze into it.
Mark (mhpautos)
Dec 10, 2009 at 6:49 AM
