1997 Oldsmobile Achieva WILL NOT STAY RUNNING
100,000 MILES • 4 CYL • FWD • AUTOMATIC
THANASI
I HAVE A 2.3L QUAD 4 ENGINE THAT WILL NOT STAY RUNNING. IT WILL START FOR 5-10 SEC THEN DIE ON ME. IF I TRY TO RESTART IT JUST CRANKS. I HAVE TO TURN THE KEY OFF AND RESTART JUST TO GET IT TO START AGAIN BUT IT DIES RIGHT AWAY. I HAVE CHECKED FUEL PRESSURE, ITS AT 50PSI. I'VE REPLACED THE IAC MOTOR THE MAP SENSOR THE TPS. I PULLED THE ENTIRE FUEL RAIL WITH INJECTORS AND CRANKED THE CAR TO SEE IF THEY SHOOT ANY FUEL AND THEY DO.
Nov 25, 2009 at 6:09 AM
  • 110,244 POSTS
Has the check engine light come on? When it doesn't start, are you getting spark?
Apr 6, 2010 at 6:35 AM
