1997 Oldsmobile Achieva timing chain tensioner
1997 OLDSMOBILE ACHIEVA
133,840 MILES • 4 CYL • 2WD • AUTOMATIC
TERRYBROCKMANN
chainged water pump canot get tensioner to tighen
Jul 3, 2009 at 10:20 AM
  • 110,244 POSTS
I believe the belt tensioner is an auto tensionier. If that is the case, it most likely needs replaced.
Aug 20, 2009 at 7:50 AM
WATERWALKERS
It works like a ball point pen. You have to pry the denter pin in slightly before it will release. do this while it's in the car with a flat screw driver. Prying lightly against the tensioner shoe.
Mar 19, 2010 at 4:37 PM
