1997 Oldsmobile Achieva heater core change
1997 OLDSMOBILE ACHIEVA
STBENTLEY62
Heater problem
1997 Oldsmobile Achieva 6 cyl Two Wheel Drive Automatic
how do I get the cover off the heater
Oct 1, 2010 at 3:23 AM
WRENCHTECH
  • 20,761 POSTS
REMOVE OR DISCONNECT
1. Negative battery cable
2. Drain cooling system.
3. Raise vehicle.
4. Drain tube from heater case.
5. Heater hoses from heater core.
6. Lower vehicle.
7. Console (if equipped).
8. Right and left sound insulators.
9. Steering column opening filler.
10. Floor air outlet duct.
11. Heater core cover.
12. Heater core mounting clamps and remove heater core.
INSTALL OR CONNECT
1. Heater core and heater core mounting clamps.
2. Heater core cover.
3. Floor air outlet duct.
4. Right and left sound insulators.
5. Console.
6. Steering column opening filler.
7. Raise vehicle.
8. Heater hoses to heater core.
9. Drain tube to heater case.
10. Lower vehicle.
11. Negative battery cable.
12. Fill cooling system and check for leaks.
Oct 1, 2010 at 3:30 AM
