1997 Oldsmobile Achieva heater blower resistor
JEAN LUC BELANGER
Heater problem
1997 Oldsmobile Achieva 6 cyl Front Wheel Drive Automatic
Can you tell me where exactly where it is located. I looked inside the car on the passenger side, but i can't see it. Maybe it is hiden somewhere inside a duct.
thanks
Dec 13, 2008 at 9:00 AM
MASTERTECHTIM
  • 4,750 POSTS
its under passenger side dash almost to the firewall right next to the blower motor
Dec 13, 2008 at 9:55 AM
MASTERTECHTIM
  • 4,750 POSTS
also there is a trick to doing this because the screw in the back is nearly impossible to get out. unscrew the 2 that are accessable then break the resister out, then remove last screw and sometimes that screw gets lost when you go to install the new one, if you know what i mean.
Dec 13, 2008 at 9:56 AM
