1997 Oldsmobile Achieva CALIPER STUCK
1997 OLDSMOBILE ACHIEVA
BETTO777
Brakes problem
1997 Oldsmobile Achieva 4 cyl Two Wheel Drive Automatic
AFTER I CHANGED FRONT PADS RIGHT SIDE THE CALIPER WAS STUCK AND WHEN I NOTICED THE WHEEL WAS OVERHEATED CANT ROLL THE WHEEL AT ALL, I NOTICED THE CALIPER IS GIVEN PERMANENT PRESION TO THE BRAKE PADS, I CHANGED THE CALIPER AND PURGED IT, AND IS DOING THE SAME ANY SUGGESTIONS? 97 OLD ACHIEVA 4 CYL, THANKS
Apr 28, 2010 at 8:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Seized brake parts are usually the sign of water/moisture in the brake fluid. I'd start with flushing out the brake fluid, and go from there.
Apr 28, 2010 at 10:44 AM
