1996 Oldsmobile Achieva runs hot
116,000 MILES • 6 CYL • FWD • AUTOMATIC
KAYEKAYE
I have changed the thermostat, water pump, and radiator but my car continues to run hot!! I purchased a timimg sensor but it do not fit from autozone and o'riely (says it should fit). can you please help me?
Oct 18, 2008 at 2:59 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b9381c149f="kayekaye"]Engine Cooling problem
1996 Oldsmobile Achieva 6 cyl Front Wheel Drive Automatic 116000 miles
I have changed the thermostat, water pump, and radiator but my car continues to run hot!! I purchased a timimg sensor but it do not fit from autozone and o'riely (says it should fit). can you please help me?[/quote:b9381c149f]
Are the Cooling fans turning on? If not check relay.
It is located on the passenger side just behind the strut tower.
Oct 18, 2008 at 3:41 PM
