1996 Oldsmobile Achieva Ceramic Brakes
DHARDIE
  • 1996 OLDSMOBILE ACHIEVA
  • 4 CYL
  • 122,000 MILES
If you have noisy ceramic brakes, do you use disk brake quiet? If you can't use disk brake quiet, what do you recommend.
Wednesday, April 14th, 2010 AT 8:44 PM
  • 109,885 POSTS
To the best of my knowledge, you can use it. They also make a product that is placed on the back of the pad's backing plate. When it hardens, it turns to like a rubber material and absorbs most of the noise from the brakes.
Tuesday, May 18th, 2010 AT 1:36 PM
