misfiring at idle and under load?
194,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHAWNE
95 achieva miss firing at idol and under load but run down hwy fine. does not stall. Plugs 85,000 on them plug boots and coil packs ogininal. I think it is one of these things any other ideas?
Nov 7, 2008 at 4:31 AM
SQM
  • 6,383 POSTS
It does sounds like the issue is weak spark plugs. As you mentioned they are the original plugs with over 85K miles.
Do an inspection of the plugs, check the gap. It should be at .060 in.
If you have excess carbon buildup it is time to change them.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Is your check engine light illuminated?
Typically with misfires the engine light gets triggered.
Also if it has not had a tune up, it will be a good idea to perform an engine tune up. Typically on a tune up you will have to change the plugs, wires, air filter, fuel filter as well as cleaning out air induction components like mas air flow sensors etc.
Here is a guide of a tune up:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Sep 19, 2021 at 1:45 PM
