1995 Oldsmobile Achieva fuel pump
1995 OLDSMOBILE ACHIEVA
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGFELLA
how do i find out if the fuel pump is out or if its just electrical?
May 24, 2009 at 12:27 PM
Do you hear the fuel pump come on when you turn key to run? If not could be a fuse or the fuel pump relay. Try powering the fuel pump from the battery if it doesn't come on then blame it on the pump, now if it comes on test the fuse/fuel pump relay
May 24, 2009 at 12:37 PM
