1995 Oldsmobile Achieva engine turns but no start
92,000 MILES • 4 CYL • FWD • AUTOMATIC
TCB476
95 olds achieva, battery died so i replaced battery, now the engine turns but will not start. I pulled the gas lines at the rear filter and its pumping gas, I changed the ignition module and both coils in the coil pack, plugs and wires are good, there is no security system. any other ideas ???
Aug 29, 2009 at 7:06 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 29, 2009 at 10:00 PM
