1995 Oldsmobile Achieva Engine is idling to high
15,000 MILES • 6 CYL • FWD • AUTOMATIC
OSUFAN10
What is making the engine idle so high? Its idling between 1,500 to 2,500 RPMS ...I know u cant adjust the idle so what could be the problem ?
Jun 5, 2010 at 12:33 PM
  • 75,988 POSTS
Clean out the idle air control valve.
Jun 5, 2010 at 1:08 PM
OSUFAN10
Where is it located? And what should I clean it with?
Jun 5, 2010 at 1:24 PM
  • 75,988 POSTS
Its on the throttle body and use a carb cleaner
Jun 5, 2010 at 2:23 PM
OSUFAN10
Replaced the valve...still idles above 2000 RPMS
Jun 6, 2010 at 3:17 AM
  • 75,988 POSTS
Check the ignition timing, also for a vacuum leak or try adjusting from the throttle stop screw and also clean the throttle plate bore or kinked/binding acc. cable
Jun 6, 2010 at 7:09 AM
OSUFAN10
problem fixed...disconnected battery and reconnected it..that reset the computer...idles great now
Jun 6, 2010 at 7:17 AM
  • 75,988 POSTS
Sounds like the IACV relearn itself
Jun 6, 2010 at 8:38 AM
