1993 Oldsmobile Achieva Engine stutter
175,000 MILES • 6 CYL • FWD • AUTOMATIC
RUTHLESSJUGGALO
I just bought this car, a 1993 Olds Acieva SL 3.3L 6cyl, the otherday. It has a hesitation to it, when it is going from a stopped postion when the RPMs are below 1700. It only does this when in drive, reverse works fine. Any suggestions as to fix this? Or what might be causing this?
Things I have done/replaced already:
Spark Plugs and Wires
Fluids and Filters(Trans and Oil)
Fuel Filter
Mar 26, 2009 at 12:29 AM
  • 110,244 POSTS
Has the check engine light come on? Have you checked fuel pressure?
Aug 20, 2009 at 8:57 AM
