1996 Oldsmobile 98 no fuel !
160,000 MILES • 6 CYL • FWD • AUTOMATIC
ROB_MENARY
hi i have been stressing over my fuel pump relay fuse i good pump will work with 12v does my ecm control the relay or do i need to pull my harness out look for bad wires pigtails look good there is 12v at one wire at pump not sure
Nov 11, 2008 at 7:27 PM
  • 75,988 POSTS
Inspect and test the fuel pump fuse and the fuel pump relay
Nov 12, 2008 at 1:46 AM
ROB_MENARY
i swaped relay fuse too.Ii found remote start previus owner it had a boild fuse melted wires ? ?
Nov 12, 2008 at 7:00 PM
