1996 Oldsmobile 98 A/C fan won't turn off at all
1996 OLDSMOBILE 98
20,300 MILES • 6 CYL • 2WD • AUTOMATIC
SANDY2NM
Yesterday my a/c wouldn't turn off on my car, even after I turned off the car. After a slight electrical burn smell on my way home, it shut down last night. But this morning, again it wouldn't shut off once I started the car. Had to disconnect the battery. Other replies say to replace the a/c relay switch that's located by the firewall. Problem is I'm a woman and not all that familiar with this, and need pictures or a better description for what I'm looking for. Is the relay box on the bottom of the cruise control box under the hood? What exactly should I order from the parts dealer? Is this an easy plug in part? Does anyone have a picture of what the relay box area looks like?
Oct 1, 2009 at 5:01 AM
Hi there sandy2nm and TY for the donation this is what keeps the site going. The blower motor relay is on right side of firewall position no. 8 below -swap or replace this relay and tell me what happened
https://images.2carpros.com/forum/automotive_pictures/12900_blower_motor_relay_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_bmr_3.jpg
Oct 1, 2009 at 5:33 AM
SANDY2NM
I tried to pull out the box that's located underneath the large fuses under the hood. I got the second one loose, but both boxes have wires attached behind the box (2 red, 2 green). So I decided I'd better check to see if this is in fact the relay switch before I go any further. I did, however, pull the large fuse in this area that goes to the AC. So at least I can now shut the car off and not have to disconnect the battery to get the AC fan to go off. I'm submitting a couple of pictures (sorry about the blur and the night time pictures). You can see the box that I've pulled loose from the holder (under the red colored fuse). Am I going for the right part?
https://images.2carpros.com/forum/automotive_pictures/416200_PA010035_3.jpg
https://images.2carpros.com/forum/automotive_pictures/416200_PA010037_2.jpg
Oct 1, 2009 at 4:30 PM
Let me reverify this are we talking about the blower motor fan or the AC condenser fan??
Underneath that red fuse is for the high speed blower motor relay for a buick left of it is the blower motor relay for an olds and pontiac
Oct 2, 2009 at 2:56 AM
SANDY2NM
I think we're talking about the AC condenser fan. I can turn the AC off in the car and the AC fan continues to run. When I shut off the car, the AC fan continues to run (initially I disconnected the battery when I parked the car, then I discovered the fuse to the AC under the hood (a large sized 10 A green colored fuse) that I could pull out to stop the fan so I wouldn't have to disconnect the battery. This is great, but now I have no AC. I bought a new 10 A fuse, but that didn't fix the problem, the AC fan would still blow continuously, so I pulled the fuse again. What do I need to replace to fix this problem. I thought it was a relay switch, but I'm not sure where that's located or what it looks like. I really appreciate your help on this!
Oct 2, 2009 at 9:50 AM
VIN K The AC compressor is at no.3 and VIN 1 is at no. 10
https://images.2carpros.com/forum/automotive_pictures/12900_ac_VIN_K_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_ac_VIN_1_1.jpg
If it continues to run-get the HVAC control assy and the computer checked out to include the blower control switch-You have a dead short somewhere within the AC circuitry.
Oct 2, 2009 at 10:22 AM
