1995 Oldsmobile 98 I need help please
1995 OLDSMOBILE 98
116,000 MILES • 6 CYL • FWD • AUTOMATIC
YUNA420
is there a a/c bypass pulley for my car its a 95 olds 98 regency elite gold edition 3.8L W/O supercharger
Jan 25, 2010 at 12:53 PM
  • 110,244 POSTS
I don't know if a bypass pulley, but you may be able to reroute a smaller belt.
You need to check to see if the car was available without AC. If it was, you should be able to bypass it. (the compressor may need removed) If it wasn't an option, you may rerout it and find that is slips on one of the pulleys because of the angle of the belt to pulley contact.
Check the belt routing diagrams on this page to see if there is an option for your car without AC.
Apr 15, 2010 at 5:39 AM
