1995 Oldsmobile 98 Fuel filter location
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
YEGRHODES
I have just recently got my Olds 98 out of the garage and want to change the fuel filter. Can you tell me where it is located?
Feb 15, 2010 at 4:38 AM
JDL
  • 16,098 POSTS
Hi, check under the vehicle, passenger side, before the gas tank. Make sure there is no pressure on the system, before taking anything loose. The filter appears to have a quick connect fitting on one end. The autostore sells a tool for releasing.
Feb 15, 2010 at 5:57 AM
