1995 Oldsmobile 98 Front belt keeps slipping off
HANOVERFIST84
1995 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
I have a 1995 Olds 98. The front belt slipped off, I put it back on correctly. As soon as I turned on the engine it slipped off again. The tensioners look fine but the idler pulley looks like it is cracked. How do I replace it?
Feb 11, 2009 at 2:20 PM
DON OLIVER
  • 101 POSTS
unplug the igntion pack and have someone crank the engine while you look at it. you should see why the belt is coming off. goodluck
Feb 12, 2009 at 12:07 PM
