1994 Oldsmobile 98 Leak
1994 OLDSMOBILE 98
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
DWSMITH63
  • 5 POSTS
i just purchased this car and it is leaking antifreeze from the front of the car right behind the a/c unit and I can't find out where it is coming from. can you advise where it may be coming from. The radiator hose is fine and tight and not leaking .
Oct 16, 2010 at 12:03 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.So are you saying it's leaking from behind the a/c compressor area?
Oct 16, 2010 at 12:45 PM
DWSMITH63
  • 5 POSTS
im not exactly sure. it is dripping off the bracket for the ac compressor and i cant see where exactly it is coming from up above.
Oct 16, 2010 at 1:46 PM
SATURNTECH9
  • 30,869 POSTS
Your going to have to get a bright flashlight and a extend able mirror so you can see where it's dripping from.You can also get a coolant pressure tester to pressurize the cooling system to help find the leak.There is also coolant leak dye but that is pretty messy when you drain the coolant.
Oct 16, 2010 at 4:42 PM
