1994 Oldsmobile 98 Heater-A/C Fan Relay?
1994 OLDSMOBILE 98
DSMITCHELL
Electrical problem
1994 Oldsmobile 98 6 cyl Two Wheel Drive Automatic
I've been told the reason the Heater-A/C Fan doesn't work is because a relay on the firewall is bad. This apparantly happened because the fan motor ceased up. I can't figure out which of the relays is the right one out of the 7 existing relays. Can anyone tell me so I get the right one the first time?
THANK YOU!
Dan
Apr 16, 2010 at 3:41 PM
There you go
https://images.2carpros.com/forum/automotive_pictures/12900_bmr_6.jpg
Apr 16, 2010 at 9:50 PM
