1994 Oldsmobile 98 dying
140,000 MILES • 6 CYL • AWD • AUTOMATIC
TABRINAH
I bought this car a few weeks ago and this is the second time i went to start my car and it is completly dead. the first time i let it sit for a hour and came back and it started. the second time which is now i went out to try and start it it was completly dead. i tried to jump it had the cables connected for at least 30 minutes if not longer and now the lights come on and it wont even turn over . so i cant even start it by jumping it..
Feb 15, 2010 at 2:27 AM
  • 110,248 POSTS
Remove the battery, fully recharge it and have it load tested at a parts store. Also, if it shows good, you need to try a draw test to see if something electrical is killing it.
Here are the directions for checking:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
One last thing, if you get it started, here are the directions for checking the alternator. Run both tests and let me know what you find.
https://www.2carpros.com/how_to/how_to_test_alternator.htm
PS: If you notice there is a constant draw on the battery, remove one fuse at a time until the draw stops. Once it stops, then you know what circuit the problem is coming from.
Apr 15, 2010 at 5:33 AM
