1994 Oldsmobile 98 Charging
SINTHEA
Engine Mechanical problem
1994 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
won't charge. runs off of the battery when charged up then dies.
Aug 15, 2009 at 8:05 AM
JDL
  • 16,098 POSTS
Hello, possibilities, faulty alternator, faulty wiring circuit. Make sure the battery has a full charge and all battery connections are clean and tight on both ends. Use a digital multimeter take a reading across battery posts, note the reading. Take another reading at the bat terminal on the alternator, everything turned off, the reading should be real close to the same, if not something wrong with the wiring circuit. There shows to be another wire, L terminal, key on, anything there?
Aug 15, 2009 at 8:21 AM
