1994 Oldsmobile 98 Blower motor won't run
1994 OLDSMOBILE 98
122,400 MILES • 6 CYL • FWD • AUTOMATIC
BUCKEYE1979
The blower motor won't run. I have tested the motor and it works. I have also replaced the blower motor relay located in the maxi-fuse center along the firewall. Is there another blower control module and where is it located? Thanks
Oct 24, 2010 at 1:28 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1994_oldsmobile_98_blower_motor_1.jpg
Have you tried testing the power and ground seperate?To see which one you don't have?
Oct 24, 2010 at 2:27 AM
