1993 Oldsmobile 98 speedometer
1993 OLDSMOBILE 98
100,000 MILES • 6 CYL • FWD • AUTOMATIC
MERCMAN4950
  • 5 POSTS
My speedometer has pegged out. I bought a replacement cable from auto zone. Is it really that simple to just pull the old cable out of the housing, measure and cut a new one? Or is there more to this than I'm being told? Thanks for all your help.
Chad
Jun 4, 2010 at 8:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
speedo should use vehicle speed sensor (VSS), no speedo cable
Jun 4, 2010 at 3:42 PM
MERCMAN4950
  • 5 POSTS
Ok thank you. Bought one and replaced with no luck. I removed the dash cover and speedometer cover and can move the needle but when I move the car in either direction the needle jumps. How do I get the gear selector lever unhooked so I can remove the speedometer? Is there any thing else it could be? I'm at wits end.
Chad
Jun 5, 2010 at 7:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
just to be clear, is your instrument cluster a digital or the standard analog type?
Jun 6, 2010 at 1:40 PM
MERCMAN4950
  • 5 POSTS
It's an analog. Everything else works. The gas hand, temp gauge, all lights. But no speedo. Does it have a motor on the back side of it? If so and that's the culprit where can I find one?
Jun 8, 2010 at 10:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no there's no motor, just the vehicle speed sensor for the speedo. does the tachometer work ?
Jun 8, 2010 at 3:13 PM
MERCMAN4950
  • 5 POSTS
Doesn't have a tach. I think its either the instrument cluster or the pcm. I can't find any other items between the vss and the speedo. Just not to sure how to test.
Thanks,
Chad
Jun 10, 2010 at 1:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no real way to test PCM other than swap it with known good one. how about the odometer, is it working? if it is then the PCM is good because the odo and speedo get the signal through same wiring to PCM.
Jun 10, 2010 at 2:04 PM
MERCMAN4950
  • 5 POSTS
Yes odometer and trip are working fine. Sounds like a bad cluster then. Thanks for all your help. You guys are great.
Jun 11, 2010 at 1:29 PM
